5.0 Swap: Which Wiring Harness
Connections on harness
  • 87-88 NO mass air, no airbag
  • 89 YES mass air, no airbag
  • 90-91 YES mass air & airbag, NO fuel pump relay
  • 92-93 YES mass air & airbags & fuel pump relay
Also know the O2 connections are unique for sticks vs. AOD. Are you planning on EFI or carb? SD or MAF? 5spd or AOD?
Mass air,EFI, 5spd.
An 89 wiring harness sounds like the best option since it does not have air air bag. There is one on eBay right now and I want to buy it however I want to be sure that its an 89 harness.
The 89 Mustang 5.0 harness if you want a used harness.
Ford Racing has an aftermarket harness if you want to shell out $500.
Here's website with lots of wiring help.
Diagrams courtesy of Tmoss & Stang&2birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Reactions: tbovee
