5.0 techs in here, backfiring issue
MustangvertGT
122
Montebello, Cali
today when I was comming home, the stang backfired on the shift to 2nd gear. Scared the crap outta me. Also, when I shift into second, it feels like the motor doesnt respond quick enough. Ill shift, hit the gas, split second pause, then it reacts. Its odd. Any ideas?
Im still taking it easy on the clutch (just installed a RAM clutch 3 days ago), so its not like im high reving. It backfired around 2800-2900 rpm.
Mods are Hedman headers, o/r h-pipe, flows,and a K&N
Also, that "pause" you are feeling is our "shift retard" for lack of a better term. It can be fixed with an aftermarket chip/tuning devise. You make adjustments to the "tip in" and timing retard settings. Basically the pause you feel is the computer slowly adding timing back in once the throttle is opened back up, ford did this to save on broken T5's.
