5.0L idling RPMs?
  • Thread starter Thread starter carlos351
  • Start date Start date Apr 21, 2009
C
carlos351
  • Apr 21, 2009
Hello Guys, what should be the iddling RPMs on this engine? reason for asking is that we transplanted it into our 71 match1 hooked up the vintage tach, it iddles ~1100RPM when cold then start going down but does not get below 1000.
thanks for your imputs
regards
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Apr 21, 2009
  • Apr 21, 2009
I like mine to idle around 800-900. The accessory drive needs to have at least 700 RPM to keep full charge and good coolant flow.
Sounds like you'll need to adjust the idle. I'm sure jrichter or somebody will post up the exact process, but suffice to say that it involves setting the idle screw with the IAC unplugged.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Apr 21, 2009
  • Apr 21, 2009
You kept it EFI right?
Unplug the IAC and adjust the idle down to aroung 600-700RPM to just about where it runs continuously but doesn't stumble.
Then unplu the batt to reset the computer, plug the IAC back in and fire it up
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 21, 2009
  • Apr 21, 2009
Ford spec is 650-725 RPM. See the sticky link below for the idle RPM set procedure.
See the "Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
P
High idle issue and leaking after running.
  • PHoffman
  • Dec 24, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 24, 2024
General karthief
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
L
Drivetrain 2000 GT High Idle - Pulling Out Hair - Help
  • lleonard1185
  • Jan 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 4, 2025
Leo090
L
