5 Lug axle question
Aug 11, 2008
254
I will be going to the junkyard this week to get my 5 lug axles. I am going to look for the ranger, bronco II, and Aerostar's for axles. I was told that I could also use 94-98 Mustang axles. Is this true? I thought the 94-04 rears had a wider track. Any help or info is appreciated. Thanks
94-98 axles are somewhere around 3/4" wider than stock or ranger axles, but they still work fine with the correct offset of wheels. 99-04 axles are even wider and REALLY need the right offset to work right on a fox, but again can be used to work.
the real reason to switch to the early sn axles is if you're also doing a rear disc conversion, as all the factory sn rear brake stuff will bolt up without any special brackets. if youre keeping drums though you have to use the ranger axles (which can be used with disc kits with a special bracket).
+1
I believe if you use the SN95 axles, you won't be able to use drums if that was what you were hoping to achieve. Look into northracecars.com for the brackets to use disks on a Fox-width (Ranger axles) rear end.
I currently have gathered 94-04 style rear calipers and brackets, dust shields, and anti moan braces. I plan on using Bullitt, or Mach 1 rims (17").
So will I be ok using 94-98 V6/GT axles, and brackets? Thanks guys
I used 96 axles (wider track) and ran a 255 rear tire with out much issue. After it was lowered it would rub a little with someone in the back seat.
