5 lug Rotors??
asecretfile
228
Friend of mine is giving me his 5 lug rotors off the front of his 4 cyl 89lx. (he started it as a project then abandoned it) He said the dust shields and all are stock 4 cyl ones. My problem is on my 87GT the dust shields look different and it looks like the bearings inside are a little smaller on the 5 lug rotors he has. When I try to install it the rotor is rubbing. It doesnt rub on his 4 cyl car, I measured and the spindles are exactly the same length and the only thing I can think of is the dust shield is shaped a little different.
If I try to use my GT bearings it fits but doesnt allow the smaller bearing on the outside go in far enough onto the spindle to get on the slotted washer, nut and cotter pin
any ideas?
thanks
4-bangers use 10" brakes while GT's use 10.8" brakes.
If you really want to use them, you'll have to remove your spindles, calipers and lines and downgrade to the 4-banger 10" stuff.
His rotors are off an 80's 4-banger ranger. If you want direct swap 5-lug rotors, you need 10.8" rotors off an 84-92 Mark 7.
Well, it seems to be hitting on the backside, does it even with the dust shield removed. (did that just to test) and also his rotor although its smaller in overall diameter, is taller maybe 1/2" as in when laying flat on the ground compared to my GT rotor
:shrug:
so an off the shelf 92 Mark 7 rotor will work and not "bottom out" so to speak like my current ones?
thanks
ok thanks
are his 4 cyl spindles deeper or something, allowing them to fit on his but not on mine? Measured 3-3/4 spindle length on both our cars. Because I noticed on the bearings they have the same inside diameter but my GT bearings outside diameter is a tad larger
Can't see what you pulled up, but i searched and it was BD60789 on there.
Just for the hell of it, check a 1990 Mark 7, with and without ABS. Sometimes one of them is much cheaper for some reason. Get the cheapest. ABS or not won't matter at all.
They should. You might want to purchase rear rotor bearing seals as mine didn't come off in one peice when i ran this setup.
I bought the Mark 7 rotors, used my original bearings and new seals.
I eventually ditched it for cobra stuff
