5-lug Swap
dbdragracing
397
I am about to do the 5-lug swap on my car. I have located a 1996 GT that is being parted out. Can I get all the parts off this car to do the swap? I know the rear end is a little wider than the Fox. Also are there any special tools that I need to remove the parts (spring compressors, etc.)? Pictures of the parts I need would also be helpful...I have a list of what I need but pictures speak louder than words! Thanks.
Can you post what all parts you are thinking? You will need front spindles for the swap and 96 model spindles are wider than your factory width on the car. This means that your front tires will be sticking out past the fenders unless you are running skinnies. You really need 94 or 95 spindles to keep the width the same as factory.
Other than that, you can use all the rear stuff, you will just be tracking wider in the rear. If you want to do it without a wider width in the rear buy the brakets from North RaceCars and use your current rearend with all the disc parts and all from the 96. If you do plan to run disc in the rear though, you will need to convert your MC to 2 port and buy a universal proportioning valve, also gut the front side of your factory PV and install the plug (part number: M-2450-A). All the info. you truly need is at http://mjbobbitt.home.comcast.net/mustang/5lug.html
just read until you can't read no more.
Thanks for the help guys...I think I can handle this swap now. Im going to sit down and try decide what year parts I need and V6 or GT parts. This yard has one GT and 4 V6s. Thanks.
The first pic shows the 98 spindle and how much the wheel sticks out from the fender with a 9" wide wheel.
The second shows the 98 6cyl spindle,brakes,and coil overs. I also bought the Maximum Motorsports braided brake hose ($80). It has the proper fittings to adapt the fox brakes to the SN 95 caliper. If you are creative you can get fittings to fit the SN95 caliper for less$$$. I like the Braided lines and the ease of application...
Well I went to the junk yard today and they had a 1994 Mustang V6 that had been hit very lightly in the rear. I purchased my parts for the 5-lug swap off this car:
-front spindles and hubs
-rear axle shafts
-(4) rotors
-(4) calipers
-(4) dust shields
-(4) banjo bolts
I got all these parts for $215!
Is there anything else I should have gotten? These being off a '94 V6....will they keep my stock track? Thanks.
The lines are with the calipers I hope?
You'll need to get an adaptor for the passenger side brake hose to go into the stock hard line.
You'll need the backing plates off the rear axle for rear disc brakes, they are oblong pieces with a hole in the middle that the axle goes through and are held on by 4 bolts to the ends of the rear housing tubes.
You're going to need some washers big enough to fit over your balljoint. I want to say you'll need a stack 0.330 inches tall on each side so you can use the cotter pin with the crown nut but that number might not be right. You can find all those details by punching 5 lug conversion into google though.
Let me see what else. You may want to grab the proportioning valve off that 94 as it's correct for 4 wheel disc. I can speak from personal experience if you don't change the brake proportioning bias when going from rear drum to rear disc you basically don't have rear brakes at all. The other option is to unscrew the front plug of the prop valve and pull out all the guts, then replace it with a solid plug as the stock one has a hole in it with a rubber grommet that simply isn't safe. If you do this you also need an adjustable proportioning valve inline with the rear brakes or you'll have waay too much rear brake bias. I picked up the plug on ebay for like 10 bucks and the prop valve for 30. I think you can get them cheaper if you're not lazy. I think it's also a good idea to get that master cylinder and I'd consider the power booster off that 94 too as your new brake calipers will want more brake fluid moved than the stock stuff did, and the 94+ mustangs came with larger master cylinders. You might need to massage the larger booster in aswell as adjust the brake pedal pushrod length to get the pedal where you want it. I also have a feeling one of the brake lines into the new master cylinder will also need an adaptor. NAPA is a good place to source brass fittings.
Don't forget plenty of brake fluid for bleeding, and always bleed from as far away from the master cylinder as possible! Meaning bleed the rear passenger corner first. Which reminds me, the rear brake caliper pistons have to be turned in, so if you don't have the tool to screw the pistons down into the calipers you'll want to get one of those too. You can use needle nose pliers but it isn't fun and you'll probably pinch the crap out of your hand once or twice.
Anyhow, that's it off the top of my head. Good luck man! The swap is defanently worth it :)
Thanks for the help....Im going to buy all new lines for the car (once I find a good place to order them from)and I did get the backing plates for the rear. Im in the process of ordering the adperters right now. Thanks.
the 93 cobra master cylinder is what comes with the M2300K motorsport kit, that one has the biggest bore between the 94-95 gt and cobra. go to www.maximummotorsports.com and they have the 3-2 port conversion lines you need to use a 2 port master cylinder. dont forget e brake cables, 93 cobra rear cables if you have a 93 or motorsport cables if you have an 87-92. here is a good ebay store that stocks a lot of parts for this conversion.
http://stores.ebay.com/Tech-Parts-Plus-More_W0QQcolZ4QQdirZ1QQfsubZQ2d999QQftidZ2QQtZkm
