Okay, over the next few days I will finally finish my 347. The engine and tranny are in the car now so its just a matter of hooking things up (actually my list of things to do is currently up to 40 things, but you get the idea). Here are 5 questions that I'm hoping to hae answered before startup:
1. I still have to put the stock oil dipstick into the stock oil pan. Is there any kind of grommet I forgot or is it just metal on metal? Any sealer or anything used here?
2. I tried to hit my starter with a direct connection to some remote battery terminals and nothing happened. Shouldn’t the solenoid have kicked in or does it need some kind of relay?
3. Any recommendations for oil cooler placement?
4. The plugs in the front of the heads, do I have to bottom them out to get a seal, or just set them in deep enough to get the alt and power steering brackets on? (I did use Teflon tape)
5. what spark plugs should I get?
I'm sure there will be more, but that's good for starters...I'm hoping to avoid needing to rush from the garage to the computer during the install.
so I'm hoping that will solve any cooling issues (then again, I still live in FL)..
