As noted in talk, I found a 93 notch 5 speed as donor for the T5 setup to go into my 79 Capri.
What do I need in the way of a flywheel, block plate and starter to put the 93 clutch and trans in the 79.
The 79 has always been a 28 oz balance, 164 tooth flexplate, C4 auto car.
Is the 93 a 157 tooth flywheel?
I think the starters are different, fitup and wiring-wise also.
If so, what is involved in using the 93 stick starter in the 79? Does it wire like a FRPP hi torque mini starter?
Can I use a set of 82 pedals for the clutch, or should I go the extra an pull the 93 pedals?
Thanks.
Thanks.
