60' times with Nitto Drag and then BFG's or MT's?
FoxRod87
243
Carolina
What are some of you guys getting at the track with Nitto's and then what are you getting with MT's and BFG's? On my Nitto's I can only get 2.10s out of them and no better. And that is with like 15lbs of air in them. How much time can I drop with a better set of tires? Thanks.
The best results will usually come in like this.
M/T ET Street radials.
BFG DR's.
Nitto 555R's.
Alot of people gripe that the Nitto's are poor at the track but great on the street. I've heard this personally and through alot of people posting their results.
BFGs totally SUCK on the street....but GREAT at the track.
Nittos are decent on the street, but arent very good at the track.
MTs FREEGIN ROCK on the street....work GREAT at the track.
From my experience, I will NEVER EVER buy BFG DRs again. Nittos....MAYBE, but most likely not.
MTs? Oh HECK yea....just have to wait for them to come off freegin back order :( (315/35/17)
Nittos require much more of a burnout than bfg's or MT's. Don't be scared to run them at 12-13psi either. With 3.73's and 260rwhp, I was seeing 1.80-1.90s on my 98. Track prep has a lot to do with it, but I would shoot for 1.85's depending on your gearing and power with the nittos. Power, gearing and track prep has a lot to do with drag radials.
not sure if my numbers are any help, auto tranny here.....anyways....
BFG Drag Radials @ 18psi - 1.75 60'ft.....started the burnout, held it for 5secs while they were smoking.
MT Drag Radials @ 18psi - 1.71 60'ft....same as above.
People complain about the nitto, but they seem to work pretty well. I've only been to the track once since I got them, and there was no track prep that night. :mad: Still, I got a best of 1.92 with my peg leg turbo car with small 245-45-17s. I'd like to see what they can do with some real track prep and a limited slip diff... or not, it'd probably break the 7.5" rear end. :lol:
You definately have to put a lot of heat in the nitto. My best 60' times came from hot lapping the car and doing a big burn out each time. I ran 18psi, but I plan to bump them to about 22psi next time, to gain back some of the mph I'm missing.
If you want tires to run only at the track, then buy the Mickey or BFG. If you want something you can drive on the street without changing your tires at every oil change, get the Nitto.
I liked my Nittos on the street and they were better then regular tire at the track. For my 96 Cobra I found the tires didnt like to be burned out for too long before they were almost greasy. If I would spin them for 1-2 seconds and had them at 20 lbs I saw a 1.92 60' Unfortunatly that was the only time I got to run her before I sold it.
BTW when I did a big time smokey burnout my 60' was dismal and the car couldnt hook through most of second and that was only a 300 rwhp car :shrug:
Almost forgot. The Pilot 2 that I have now really handle 450 rwhp nice. They hook better then my Nittos did. Down side is $472 each :notnice:
