64-66 discbrakeswap kit F/S BNIB
BullittStangV8
1,104
NJ
64-66 diskbrakeswap.com SWAP.2.1.3/M kit for manual brakes/manual steering. Brand new, never mounted. Boxes were opened to get the packaging slip and to verify the contents. Perfect condition. Asking $500 + Shipping OBO. :flag:
I'm sorry, kinda new to the scene of the classics - Can you explain the granada type brakes, and also make a list of everything in it?
I"d like disk brakes, but I'd also like it to match my rear axle, which is coming from a 94GT.
Thanks
I do not believe it works with 6 cylinders due to the steering gear/tie rods. It works for 64-68 v8 manual brake cars. the kit includes:
The kit includes everything needed to swap out your front drum brakes for "Granada" type OE style disc brakes. All new parts including high strength alloy steel spindles, a dust shield kit, caliper brackets, corrosion protected calipers, semi-metallic pads, brake hoses, hose brackets and attachment hardware, adjustable proportioning valve, residual pressure valve, master cylinder, master cylinder outlet adapter(s), an adjustable pushrod (manual brake applications), wheel bearings, wheel seals, caliper attachment hardware, wheel attachment hardware, dust caps, performance slotted rotors with bearing races pre installed, outer tie rods correct for your application, Grade 8 attachment bolts, red and blue thread locker, and caliper lube.
