65-66 toploader and brake parts + misc
DJCarbine
392
I am located in chicago, would prefer local pickup only.
3 speed toploader out of my 66 289 C code. Shifts fine, comes with shifter handle, linkage, and bellhousing+block plate. 2nd gear had a growl to it, so you might want to consider a rebuild somewhere down the line. I drove it for years like that though, so its not critial.
Front drums and backing plates + hardware with shoes. Replaced fronts with a disc setup, the front drums were turned less than 5k miles ago and the shoes also have less than 5k on them. Backing plates have brake hose attached, and the hardware such as springs are all there.
Gauges from 5 guage cluster. This is for just the gauges themself, not the bezel or anything. All guages work to my knowledge. Speedo is a 140 mph.
Original 2bbl intake manifold, spacer, and autolite 2100 carb. I also have the emissions aircleaner with the part that goes down and attaches to the exhaust manifold. Needs to be cleaned up, but otherwise good condition.
I will accept resonable offers and trades.
