Yeh I know they never work anyway. But when finally getting my car going, with my brake handle pulled out as hard as possible and the cables seemingly tight, the car rolled easily forward and backward, and I had checked everything many times. I know it won't hold on a hill but sheesh it ought to hold just a bit on a slight incline on my driveway
Anyway found this picture of a 66 but same idea, notice the equalizer rod assembly attaches to the equalizer lever in the hole nearest the pivot (center) point, with the second (outer) hole on the lever for the spring attachment. On mine I had assembled it based on an old assembly manual drawing and had the rod attaching to the outer hole. Well that was just enough to lose any mechanical advantage such that pulling the hand brake out as hard as possible did essentially nothing. I switched the rod's position to the inner hole, readjusted, and now cannot roll the car at all on a flat surface either direction. I'll try tomorrow on an incline and see how it is, but its gotta be better than it was
So for the 65-66 folks check the equalizer rod/lever assembly make sure it conforms to the picture below, it might help you
