65 EFI conversion, MegaSquirt-II
Sounds like a fun project. I'm very happy with my MSII.
Are you planning on using factory EFI hardware and just ditching the ford ECU?
with the megasquirt controller, you ditch the ford ecu. the negasquirt is a stand alone unit. it is however a batch fire system though, but that is no problem with a gas engine. you can also get an ignition controller if you like. check out;
http://www.bgsoflex.com/megasquirt.html
Red, I see guest users logged so not sure of problem. Maybe just register, should be free.
I'll use some factory and some aftermarket. That link is the older MSI. I'll outline the system once I've picked them all, still deciding and building the CPU, bought the un-assembled kit.
