65mm throttle body problem with the tps
mustangkid2.3
344
Piqua, Ohio
how do you get the tps to hook up on this? do you use your 2.3 tps? or is there a way to use the 5.0 tps? the one that came on my new throttle body doesnt look like it can be moved to adjust is like the 2.3 one..will it just work right if i get it on there, and figure out how to hook it up to my car? somebody please help..thanks
SPEED FREAK said:
BOOOOOOOO!!!!
Use aluminum. May need to buy an electric grinder and some cutting bits tho ;).
it came across my mind..but i dont know exactly where i would get a piece of it at...the sheet metal i got from work and are only little planks of it no more then a quarter inch thick, and 3 inches wide.
