I am helping a friend of mine try to diagose a hard brake pedal on an original 390 4 speed, 67 GT. We are both at our wits end and just about given up on this problem. The car came standard with front dual piston discs. This car has also had a full restoration, meaning all new stainless brake lines, brake cylinders, calipers, distribution block, rubber hoses and of corse a new booster and master. He first took it to a repair shop here in the Detroit area that specializes in Fords. They sent the booster out to Booster Dewey in Oregon to have rebuilt, tried another master cylinder, still no luck. Today, we pulled the master off again an readjusted the brake pushrod, thinking it was not pusing the master cyclinder far enough and rebleed the brakes, with the same hard pedal results. I checked manifold vacuum and read 12 inches, a liitle low , but I think should work.
If anyone has a clue what could be wrong, We're open to suggestions.
Thanks!
Mike
Thanks!
Mike
