69 351w vs 90 351w
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
im about to get a motor to pull down and start building it.. i can choose between a 69 4bbl motor.. or a 90 windsor.. difference is i know of ones a roller and ones not.. which block is stronger??? im building a stoker looking for 500+ so it needs to be strong
pb_paulie_b said:
Thicker main webbing. You can go 4 bolt main if you want. Higher nickle content....
Yup.
:SNSign:
And you can 4 bolt the other 351W blocks,but the 69' has flat main bulkheads,whitch makes it alot easier.
I wonder if there is a differance in cylinder wall thickness?Hmm....
The 69-74 blocks all feature thicker mains/walls.
The 69-70 is a 9.48" deck height
71+ is 9.503
Keep that in mind when you look at rotating assemblies, it is very important of the pistons will be sticking out of the bore.
i have a 72 351w block and have had no problems with it. I would say go with the stronger 69 block. Another thing that differ's in the 2 blocks i believe is the 69 is a 2 piece rear main seal and the 90 is a 1 piece. i would also think that the 69 block would be a little heavier.
