J jshcobra Founding Member Jul 5, 2000 720 0 0 Aug 4, 2004 #1 Aug 4, 2004 #1 Does the 70 flip open gas cap assembly fit on a stock twist open 70 car without mods? If not, what needs to be done. Thanks.
pabear89 Active Member Apr 15, 2003 2,126 0 46 High in the Hills of So Ca with the Voices in My H Aug 4, 2004 #2 Aug 4, 2004 #2 Yes, just remove the old filler pipe and replace it with the flipopen . PB
mfp4073 Founding Member Mar 14, 2001 387 0 38 Hells Ditch, FL Aug 4, 2004 #3 Aug 4, 2004 #3 On my 67 I believe I just removed the cap assembly itself and then installed the pop off one without replacing the filler neck that goes to the tank.
