  • 1994 - 1995 Specific Tech
70 mm Throttle Body
  • Thread starter Thread starter 94comp
  • Start date Start date Mar 3, 2007
9
94comp
22
Macomb, Michigan
Mar 3, 2007
  • Mar 3, 2007
I just installed a 70 mm throttle body,, currently I have a 94 5.0 AODE w BBK CAI, BBK Underdrives and now this 70 mm. I took the car for a ride after installing and letting idle for 40 min and the pick up is great from a standstill, but from a 25 or 30 roll it just bogs down for a sec or 2 before it catches itself. I will be installing shorties plus exhaust back in a matter of weeks and I hope its just a matter of the exhaust not breathing enough. But I'm open to suggestions anyone else ever encounter this??? I'd appreciate it
I took it for another drive today to totally test everyones input before I removed the TB... and it seemed to run well besides the fact that it bogged down between 1000 and 1500 rpms ( roughly) from an idled start it was fine and anywhere it was in gear above 1500 it also was fine. Could this be an injection problem or possibly a MAF prob?? Any other input would help. I checked all my connections and ports everything is hooked up fine no leaks I can see. Those are the only 2 things I can think of?? Thanks again
9
95Mustang302
302
  • Mar 3, 2007
70mm is a bit big for a stock engine, remember bigger is not always better...
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 3, 2007
  • Mar 3, 2007
The 70mm is FAR from too big. Did you port match the inlet on the manifold to 70mm? Are you running a 70mm adapter? I hope you didn't put a 70mm tb on a 60mm inlet????
WHITE94COBRA
816
HUNTINGTON BEACH
Mar 3, 2007
  • Mar 3, 2007
Ohhhhh good lord another TB thread.......... What your feeling is the computer relearning, there is such thing as too big but 70 or 75 is not it. Please port match the inlet, otherwise your defeating the purpose of a larger TB. I can go on and on about Tb's; just remember if anything before or after the TB is smaller than what you put on it's a restriction.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Mar 3, 2007
  • Mar 3, 2007
The 70mm TB flows WAY more than the engine needs. It is proven. Go check accufab's website on what an engine (302) flows and you will see the 70mm TB flows much more than the 302 engine.
But...that will not make it act like it is. Sounds like a mechanical issue or the intake is not matched to the 70mm TB opening.
gcomfx.com
3,690
Republic, MO
Mar 3, 2007
  • Mar 3, 2007
How old is it and what brand? I have a 65mm BBK I might trade you (with $$$ if yours is better of course).
I have a 331 about to go in the car with a Trickflow Track Heat intake. ;-)
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Mar 4, 2007
  • Mar 4, 2007
Sound more like a vacuum leak and I agree 100% with 5spd GT good luck.
9
94comp
22
Macomb, Michigan
Mar 5, 2007
  • Mar 5, 2007
Someone help me understand this, Intake opening to throttle body opening
  • from6to8
  • Jul 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
from6to8
Throttle body cable
  • Nostang25
  • Sep 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2025
AeroCoupe
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Engine 1990 5.0 bogs and pops over half throttle
  • Sander
  • Aug 1, 2025
Fox 5.0 Mustang Tech Aug 2, 2025
AeroCoupe
