  • SN95 4.6L Mustang Tech
70mm TB or 75???
  • Thread starter Thread starter kyles03sonicgt
  • Start date Start date Jan 12, 2006
K
kyles03sonicgt
111
Berkley, Michigan
Jan 12, 2006
  • Jan 12, 2006
About to order an accufab throttle body and plenum. I know this topic has been discussed before, so I apologize. I am leaning towards a 70mm, because I am not getting a blower, but am probably going to get a 75 shot of nitrous. I am doing full bolt-ons with stage 1 vt cams. What would be best??
imblown-ru
247
Roanoke VA
Jan 12, 2006
  • Jan 12, 2006
if you do get all of that you should be good with the 75 mm. get it. youll love it anyways. it may not be ideal at first, but once you are fully modded it will help you
reddrgn01gt
161
Pittsburgh, PA
Jan 12, 2006
  • Jan 12, 2006
Go with the 75mm if you plan on getting cams and nitrous.
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Jan 12, 2006
  • Jan 12, 2006
75mm.
off-topic. I know the accufab has been proven to make more power than the others (except BBK, havent seen a dyno test with that on yet). But is it really worth the extra $100-$120 just for 1-2hp? If you need every bit of power, then I guess it could be, but as much as I'll admit Accufab is the best, I dont know If I'll ante up the extra cash for that marginal gain.
goshia
252
Mead, Colorado
Jan 12, 2006
  • Jan 12, 2006
What price have you found for the parts, I am just about the buy the same set-up,,, 75mm
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Jan 12, 2006
  • Jan 12, 2006
75mm TB + plenum from accufab
goshia
252
Mead, Colorado
Jan 12, 2006
  • Jan 12, 2006
I found the Accufab set for the following price's:
Accufab 75mm TB $219
Accufab 75mm Body & Plenum $419
Both polished.
As anyone else have found a better price???
helty
Mar 30, 2005
1,461
Baltimore, MD
Jan 12, 2006
  • Jan 12, 2006
Both polished.
Thats about the best you're gonna find anywhere. I still cant bring myself to spend the extra $100 for 1-2hp.
reddrgn01gt
161
Pittsburgh, PA
Jan 13, 2006
  • Jan 13, 2006
429 shipped from lmperformance. Not sure what shipping would be on it.
billfisher
1,296
huntsville, AL
Jan 13, 2006
#10
  • Jan 13, 2006
  • #10
do what you think is right....
perception is 9/10th's of the law.
hey dude, if you want EVERY hp you can get then it will cost you.
are you trying to make HP on a budget, or are you trying to get ALL of the hp a 4.6 will make?
if you are after every hp... every last stinkin HP the go 75mm accufab. 2 hp here and 2 hp there will get you where you want to be. forget price. whrn i get toward the end of this project i will be paying 100's for a single hp. maybe thousands for a handfull.
bas you decisions on which path you are on. it will save you from buying the same parts over and over trying to reach a difficult goal. just ask hotmustang331 what he would pay for a dozen rwhp right now.
you just have to decide which path you will take.... BEFORE you start spending. BBK is an excellent TB, i like it, but if you need an extra 2hp then accufab is worth much more.
rock out with your ( o ck out.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Vortech V3 Si - Bypass Valve to BOV swap issues
  • seanmahoney
  • Jun 26, 2025
SN95 4.6L Mustang Tech Jun 26, 2025
seanmahoney
