72 Mustang Running Rough
  • Thread starter Thread starter Hawkk72
  • Start date Start date Nov 30, 2007
H
Hawkk72
47
  • Nov 30, 2007
Have a question...Distributor all the way advanced and still runs very rough and will stall out eventually. Could the distributor be 180 degrees out? How would that happen and how do I get it back to the corect position? Car is a 302 with Edelbrock manifold and Edelbrock 4 bbl carb. Car runs like it has a bad vacuum leak somewhere. I've checked for vacuum leaks and found a couple of minor ones which I repaired but nothing serious. Car has new plugs, point gap is correct at 17. Can't tell if the timing is correct or even close because I can't find the mark.
rbohm
6,698
550
204
tucson,az
Nov 30, 2007
  • Nov 30, 2007
first the distributor cannot be 180 out otherwise the engine would not run at all. second it sounds like you have a vacuum leak. torque the intake down and see if that helps any, as the leak may be on the under side of the intake. second, set the idle mixture screws to the smoothest idle you can get. you also need to set the idle speed(in drive if an automatic). ignition timing should be between 10 and 14 degrees initial. check the plugs, point setting, valve adjustment.
R
RUSTYNUT
128
PDX
Dec 1, 2007
  • Dec 1, 2007
You are going to have to locate the timing marks. Use some paint or crayon to make it easy to see. You can't time your engine with out seeing the marks. Do you have your dwell time set to specs? Unless you want to keep your car original, save your self alot of head aches and use electronic distributor. Sound like a vacuum leak is your main issue. Be careful on over tightening intake bolts as you can break bolts and manifolds that way. That Edelbrock carb uses 7psi max. fuel pressure. If your floats aren't set right or running Holley fuel pumps could be flooding.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
