Have a question...Distributor all the way advanced and still runs very rough and will stall out eventually. Could the distributor be 180 degrees out? How would that happen and how do I get it back to the corect position? Car is a 302 with Edelbrock manifold and Edelbrock 4 bbl carb. Car runs like it has a bad vacuum leak somewhere. I've checked for vacuum leaks and found a couple of minor ones which I repaired but nothing serious. Car has new plugs, point gap is correct at 17. Can't tell if the timing is correct or even close because I can't find the mark.
