75mm MAF tube question
i was thinking about doing the samething. its hit or miss. some people put them on and they have idling issues and drivebility. on fox bodies, it works great. i could be wrong. please someone correct me about this mod :rolleyes:
I assume this is with a C&L meter housing? If you have the correct sample tube and just bolt on your stock sensor it will run.
I am not a fan of C&L meters for our years due the the greater chance/risk of drivability issues. They do work somewhat though...in that the car will move under its own power, get down the road, and in most cases run ok at the track.
However, if your picky in any way about drivability issues then look at a different maf.
If this is just some 75mm maf housing that your going to bolt your stock sensor to. I doubt it will work...and if by some chance it does start I doubt it will run worth a damn.
