8.8 gears please help
dfwcobra
I have a 306 with 93 cobra heads ported, trickflow stage 2 cam and c4 tranny w/3200 stall and trans brake. Tires are 26x10.5x15. I will be running nos w/ carb plate maybe 150 shot. Question is what would be a good set of gears as far as ratio goes for a 1/8 mile track? Any help would be great. Thanks
Best way to do this is to crunch the numbers. What rpm do you want to cross the finish line?
Give yourself a coupe hundred rpm cushion, and take that rpm back to see what gears you need, with your tire size to get that.
I have 410 gears, 275-50-15 BFG Drag Radials, and I cross the finish line at about 6000 in the quarter mile at 105 mph.
I set it up for eigth mile and I don't dare run much faster on a quarter. I have tried a 456 for eigth mile, but I cant run the quarter with it.
Is this also a daily driver? If not does it see a lot of steet time? If so, I'd say a 3.55. 3.73 for a more strictly 1/4 mile car. 4.10+ if only an 1/8th mile car. I had 4.10s in my old AOD GT and didnt like them very much. Should have went with a 3.73. But i recommend the step lower to you just because of your power adder.
You said track only. What mph do you expect to run in the 1/8th.
With 26" tires and a trap rpm of 6100, here are some trap speeds I calculated (I have an excel spreadsheet for gear vs. speed).
3.73 @ 6100 = 126mph
4.10 @ 6100 = 115mph
4.30 @ 6100 = 110mph
4.56 @ 6100 = 103mph
Hope this helps.
