Yes there is. It's not as cheap as the '87-'93, but it involves those calipers.
You will need: '87-'93 spindles, rotors, flexlines,and the lincoln 73mm calipers.
If you do your shopping in the junkyard, you should be able to do it cheap. I would strongly reccomend that you only use the spindles from the scrapyard and buy everything else new. If you luck out you may be able to find decent rotors and the Lincoln calipers at the wreckers too. If you buy the rotors new, you are going to need the bearings that go in the back of them as well.
