16v system with an alternator tends to hate on my light bulbs, lol. (Charging it sees almost 19v)You've got a tail light out
Jesus Christ. will there be 110v outlets installed too for my devices before lift off LOL16v system with an alternator tends to hate on my light bulbs, lol. (Charging it sees almost 19v)
If that's all the ball breaking coming my way then I will certainly not get a sandy twatwaffle @srtthis
what size pulleys do you run? we had to unhook the alternator on the turbo car it was seeing 21v16v system with an alternator tends to hate on my light bulbs, lol. (Charging it sees almost 19v)
Dont need no brake lights, at thst speed noone will see them anyhow
Its hard to go by just the pulley size on my alternator. The alt is driven by the blower hub on the output side of the gear drive. It has a 1.88 step up gear set in the drive right now and uses a cog belt to drive the alternator.what size pulleys do you run? we had to unhook the alternator on the turbo car it was seeing 21v
You sir are a smart a$$ lol. I really tried hard to dumb it down enough for youAll i see are tenticles
@84Ttop the man has spoken . seems this is what your fate is !1st off your fancy camera didnt have an obvious zoom in movie mode be happy you got what you did I usually have a tendency to shut it off after launch anyway lol
2- Ill decode your lightbulb scenario - voltage is too high, cheap ass bulbs cant hang with it and we too lazy to do the math to tell you what the voltage is based on rpm and step up ratios etc... but datalogger see@ 17.9 volts at higher rpm when on dyno![]()
3- I already told ya 3.25 gears AND 30" tire will get us better gas mileage and that stuff aint cheap! If slows down ET we need more boost and there is a xb110 sitting on my counter.....
