That's the plan, I may put a second third member together to be able to switch between a 1/4 mile setup for TrueStreet and an 1/8 mile setup for X275Very nice, good to hear that the car is running great as well as consistent. Are you going to a higher gear to dial it in better for the 1/8?
We are in second gear (1:1) with a powerglide and cross the 1/8 @ 7450rpms with the 3.50 gears. I would expect/want the car to cross in the 8000-8200rpm range with the 3.89 gearsWhat gear and what rpms are you at when you reach the 1/8?
Thanks! That UPR hook has been so consistent, every pass the car gets down the track and clicks off low 1.20's!Nick's car is a BMF! Not a lot of street cars can make the field in X275, and run a 5.0 1/8th with a 1.23 short time!
What cracks me up the most is every single other car is towed to the line and towed back to the pits. We drive it to and from and never have an issue. Most other racers in the class look at us like we are crazy, lol
Some don't have a charging system and other don't have a cooling system. I know a fair amount of cars have a surge tank that they fill with ice in lieu of a radiatorDo the guys being towed up to the line not have a charging system?
we got both and still get towed up!I just ordered/received a new center section for the car to put some more gear in it and hopefully pick up a little ET. The 3.50 gears that we had will stay as the 1/4 mile setup and we are hoping that the 3.89 will work a little better for 1/8 mile. I just got back from a vacation so I will be swapping those this week in hopes to head back to the track very shortly!Anything New?
I will look as soon as I get home tonight. I totally forgot until just now, hahahasince your back lemme know the OD of that cutter![]()
