No crankcase evac pump, just 2 -16an vents one from each valve cover. In speaking with Mike Moran about the a pump, he assured us that there was no pump that will pull enough vacuum on this particular combo.Are you running any kind of a crankcase evac pump at all? Do you drain the fuel after a race weekend and put regular fuel in it and start it up and let it run for a min or so to get rid of all of the residual meth in the fuel system? Do you spray the engine inlet with the likes of Seafoam or Marvel mystery oil or something similar to prevent cylinder head/combustion area corrosion?
The fuel gets drained if the car sits for longer than a few days, it's a bit tricky to get the car to run on gas with the 500lb injectors and 90lbs of fuel pressure. The motor gets sealed at the collectors to try and keep it from corroding, It will be rebuilt in the winter regardless of what happens
