Thanks Hissin and Maverick, I learned a little something -- that clears it up. In 85, the automatic "HO" were CFI at 180HP; the 5 speed HO's were carb'd at 210HP. For 86, everything went to sfi - the speed density system. In 88, CA went to mass air sfi; in 89 everything did.
Blah - a roller motor is one that has roller lifters. Most pushrod V-8's out there had what's called a flat tappet lifter to follow the cam lobe. The metal lobe sat directly against the flat metal bottom of the lifter. A roller lifter has a smaller wheel or "roller" on the bottom that sits against the cam lobe. Since it can 'roll' around the lobe, there is less friction, and the lobe ramp rates can be steeper allowing more area under the lift curve - more aggressive camshafts. Go to the link posted by hissin above and see if it will tell you the history of roller motors in the Stang's - according to Dark Knight above, if it's CFI, it's a flat tappet motor. The only way I know of for sure is to pull the intake manifold - the roller motors have a piece of sheet metal bolted in the valley that keeps the lifters from rotating in their bores - called a spider for obvious reasons when you see it. If you see the spider, you've got a roller motor.
