86 Mystery Mods Progress!
  • Thread starter Thread starter Slobin3d
  • Start date Start date Sep 25, 2017
  • 7
  • 8
  • 9
  • 10
First Prev 9 of 10 Next Last
Slobin3d
246
17
38
Jan 26, 2018
#161
  • Jan 26, 2018
  • #161
Mustang5L5 said:
Throw that one in and see how it runs. I'd reset the ecu and then install.
The larger MAF with 55 mm electronics is probably telling the ECU you are seeing less airflow that you really were. Probably why it was idling up.
Don't chuck the larger MAF though. You just need to find the sensor with the p:n I listed and install it on that.
Running the 55mm MAF with 65mm TB is probably costing you 1-2hp. I wouldn't swear it. Get car running right and then upgrade later
The mismatched diameter was my main concern, but when I originally started looking at it, I thought the TB was smaller then the MAF, not the other way around. Lol
It's worth a shot, I already have it. And I can always resell it later.
As for the cutting out at half throttle under heavy acceleration, it did that before the MAF conversion. Still haven't sorted that out yet.
Admin Dude
Jan 4, 1985
43,548
21,716
234
Box behind Walmart
Jan 27, 2018
#162
  • Jan 27, 2018
  • #162
Mustang5L5 said:
Explorer MAF will not work on a Mustang. The MAF transfer function is not correct.
..without a digital tune of the EEC.
The biggest problem I see with mismatched housings and sensors is that there's no way for you to get the transfer function correct without a flow-bench machine.
You guys may already have covered this. I only skimmed through.
My advise would be to do some simple math calculations for air volume and purchase a new meter complete with 30 point transfer function (for later tuning if necessary) and to buy it in the size needed for the injectors and EEC that you plan to use.
It really is the path of least resistance.
Again, sorry if this has already been covered. ( I'm currently searching for DBS spoilers )
Slobin3d
246
17
38
Jan 27, 2018
#163
  • Jan 27, 2018
  • #163
Mustang5L5 said:
You need a factory paired MAF sensor and housing. Can't swap electronics. That small bore the wires sit in is critical to how it calculates airflow.
So with 19# injectors you either need to track down a stock 55maf housing, or the correct electronics for that housing. The part number for those electronics is F2VF-12B579-A2A.
@Mustang5L5 I found a used one on eBay, but I'm having trouble crossing the PN for a new replacement. Is that meter out of a 94-5 5.0 mustang? Or a 4.6 car? Or Lincoln of some sort?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jan 28, 2018
#164
  • Jan 28, 2018
  • #164
Here's where you can find it
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang GT & Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Reactions: Slobin3d
billison
I like tinted tail
2,607
1,094
184
stl
Jan 28, 2018
#165
  • Jan 28, 2018
  • #165
Incase it was missed, I would trash metal intake tubes that have rust in them like that. Rust will flake off and do god knows what.
Slobin3d
246
17
38
Jan 28, 2018
#166
  • Jan 28, 2018
  • #166
It's all going away. It's too small anyway. I'm guessing the PO bought some cheap kit and made it work.
Slobin3d
246
17
38
Jan 28, 2018
#167
  • Jan 28, 2018
  • #167
I swapped in the smaller MAF. It improved the surging idle quite a bit, not 100% gone yet, but close. Now I need to get the idle down below 1000 rpm.
Iirc isn't it, that you pull the throttle position sensor plug, and with it running set your base idle screw?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jan 28, 2018
#168
  • Jan 28, 2018
  • #168
Pull the IAC plug, set base idle screw with IAC unpluggged, then you need to reset the ECU (unplug battery 30min).
Hook it all back up and restart. Idle 2 min accessory off, then 2 min everything on.
Wouldn't be a bad idle to run the codes after a few start/stop cycles.
Reactions: Slobin3d
Slobin3d
246
17
38
Feb 13, 2018
#169
  • Feb 13, 2018
  • #169
New development....
Went to test my fuel pressure, fired the car up after hooking up the gauge, no leaks, and it ran for about 30 seconds, then died. Restarted, and ran long enough to get around to look at the pressure gauge, then died. Did that 2 more times then no fire. Gauge read 40 pounds, and even after if wouldn't fire it would run up to 40. As soon as I shut it off it would drop to 10 psi
Pump sounds quite compared to normal, and I picked up a 255lph to swap into it anyway.
I can't seem to find my inline spark plugs tester, but that's next on my list of tests
Slobin3d
246
17
38
Feb 19, 2018
#170
  • Feb 19, 2018
  • #170
A positive update!
The pickup was bad in the distributor, cause the car to die. I picked up a new one, and after chasing down a bad "new" tfi that came on the dizzy, she runs again.
Not only that, but my high rpm dead spot seems to almost be gone. Instead of it quitting violently at 2800~3000 rpm it kind of falls off at 4800, 2nd gear is more abrupt then first.
It's an improvement. I reset the timing to 14°, back to where it was. Should I drop it back to 12 or 10, and see if it helps, or would that not cause my cutting out issue anyway.
I'm not hearing any ping as it sits
General karthief
Mod Dude
Aug 25, 2016
28,124
10,743
213
polk county florida
Feb 20, 2018
#171
  • Feb 20, 2018
  • #171
You could try backing off the timing but honestly I don't think it's the problem, I would check the tps sweep but I figure you've already done that.
Slobin3d
246
17
38
Feb 20, 2018
#172
  • Feb 20, 2018
  • #172
Ok, I have checked it in the past, but I rechecked my base tps voltage and it was at 1.01v, so I backed it back down. But last I checked it was still below 1v, so unless it moved on me, it's maybe not holding a consistent voltage?
General karthief
Mod Dude
Aug 25, 2016
28,124
10,743
213
polk county florida
Feb 20, 2018
#173
  • Feb 20, 2018
  • #173
Check the sweep voltage, hook your meter up and see if the voltage rise is smooth all the way to wot. I had a bucking problem at 1500-1800 rpm I chased forever, my tps was at .98 but as I moved the linkage simulating acceleration and it was bouncing the meter to 0 at what would be about 1500 to 1800 and then was smooth after that, like a flat spot, smooth above and below.
The static voltage is not that important as long as it's close to 1 volt
Reactions: Slobin3d
Slobin3d
246
17
38
Feb 21, 2018
#174
  • Feb 21, 2018
  • #174
I reset base idle from 1000 to.around 700, and 8 rechecked the idle voltage, it had jumped back up to 1.1 . I flipped the tps 180° where it allowed a bit more sweep, and seems to be holding at .98, but I can't go any lower.
I did a sweep test, and it's solid, no dead spots. I did however find that the throttle feels a bit gritty. Not enough to hold it open or stick closed, but it feels like maybe there's a bushing or bearing that's out, maybe the butterfly is rubbing in the housing. No vacuum leak though.
Slobin3d
246
17
38
Apr 11, 2018
#175
  • Apr 11, 2018
  • #175
So I replaced my fuel pump with a 255lph and the fuel filter, good thing too, it was zip tied to the sending unit, there were all kinds of trash in the tank, a old pickup sock, and chunks of plastic, the fuel filter was held on with more zip ties, and the locking clips were broken and ziptied to the hardlines.
Drives much better with the new pump, but by accident I did a run with the idle air unplugged, and it runs great without it, no.mid throttle hesitation. Idles like crap, and sometimes dies, but off idle it's perfect.
I didn't think the IAC, did anything off idle?
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Apr 15, 2018
#176
  • Apr 15, 2018
  • #176
Maybe its shorting out giving the ecu bad info.
stpete
Well-Known Member
Dec 26, 2015
320
151
63
Apr 17, 2018
#177
  • Apr 17, 2018
  • #177
I haven't read all the responses, but your car seems to be in the condition that mine was. The checklist mentioned by Noobz a couple pages back took me quite a while to get through, but eventually got my engine running/idling smooth.
Also, be careful not to run your AC without the fan running. The AC will be blowing it's top before you even see your engine temperature start to climb. My recommendation is to go back to mechanical. I still owe the guy that hid the fan switch under the dash in my old car a kick in the nether region.
Slobin3d
246
17
38
Apr 26, 2018
#178
  • Apr 26, 2018
  • #178
Went to fix the inop speedo, found that the cable at the trans had been cut, and the VSS removed, and plugged. I replaced that with a new one and red gear to match the 3.73 gears. That help a bit with getting the idle to settle down. And now I know how fast I'm going.
Reactions: 90sickfox
Admin Dude
Jan 4, 1985
43,548
21,716
234
Box behind Walmart
Apr 26, 2018
#179
  • Apr 26, 2018
  • #179
I'm not sure why but the server put your post into moderation. Let me know if that keeps happening.
General karthief
Mod Dude
Aug 25, 2016
28,124
10,743
213
polk county florida
Apr 26, 2018
#180
  • Apr 26, 2018
  • #180
He may need a little moderation now that he knows how fast he's going
Reactions: Slobin3d
  • 7
  • 8
  • 9
  • 10
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
