N NooStang Member Mar 15, 2024 17 3 13 Tn Thursday at 1:15 PM #1 Thursday at 1:15 PM #1 If not too much trouble, hoping someone could measure the air filter box base standoffs - height and diameter, excluding the threaded section. Attachments Box.PNG 84.6 KB · Views: 15 Last edited: Thursday at 1:27 PM
85GTStangGuy Advanced Member May 19, 2021 628 392 73 Florida Thursday at 1:56 PM #2 Thursday at 1:56 PM #2 Don't know the dimensions, but if you're looking for the actual parts.... https://lmr.com/item/LRS-9686K/1986-93-Mustang-Air-Box-Hardware-Kit
N NooStang Member Mar 15, 2024 17 3 13 Tn Thursday at 2:12 PM #3 Thursday at 2:12 PM #3 Thanks for the link, but was planning to just 3D print a couple. Reactions: 1 users
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 37,040 17,808 234 Box behind Walmart Thursday at 2:47 PM #4 Thursday at 2:47 PM #4 In PETG, PLA, or ABS? I don't think the PETG is going to hold up well in the engine bay (what most folks print with). ...and isn't it [hot] where you live?
N NooStang Member Mar 15, 2024 17 3 13 Tn Thursday at 3:11 PM #5 Thursday at 3:11 PM #5 Will try ABS. If ABS can't stand temps then I will break out the lathe once I get dimensions correct. Reactions: 1 user
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 37,040 17,808 234 Box behind Walmart Thursday at 3:28 PM #6 Thursday at 3:28 PM #6 NooStang said: Will try ABS. If ABS can't stand temps then I will break out the lathe once I get dimensions correct. Click to expand... I think the ABS will hold up under the hood for the airbox as long as it's not around oil and grease. Reactions: 1 user
