Artificial HID Bulbs? Sounds like an eBay listing to me.
XenonDepot.com is a great place for true HID kits. 4300K and 6000K kits with Phillips ballasts - the only way to go. I helped a friend install a setup in an Accord - all wiring was included, entire process took like 30 min thanks to the nice setup XD offered. XD has eBay listings too.
As far as frying the wiring - if you get a TRUE HID kit with HID bulbs, ballasts, wiring to match up with the 9004 type stock bulbs, you will not come close to frying the wiring. This is especially true of the XD kits as instead of pulling power from the factory harness, they run a fused line to the battery. The factory harness is used as a relay signal to essentially notify the HID setup when it is time to turn on and off.
Also note that unlike our stock 9004 bulbs, HID bulbs are either low or high beam. Luckily a 4300K or 6000K setup will be PLENTY of low beam power that you will never long for high beams.
