87 gt cranks got spark got fuel stays started when i hold key turned help asap
davidohio
17
i got an 87 all stock 5.0 i got spark and fuel pres car ran fine for over 1 month then i ran into this problem again it had a aftermarket alarm in it i ripped it all out then the car would stay started only if i holded the key to the on pos but the starter would grind i started screwing around under the coluem area with a fwe wires and then it started normal so a month later i changed the battrey other day got on the high pow dead same problem soon had i chnaged the battrey before that car ran awsome i figured the coluem wires was screwed up again so i went today brouth a whole colum installed it and turns out it anit that now iam lost again i got spark and fuel so its not that the car ran great fwe days ago
Hmm...almost seems like the fuel pump isn't getting switched on. I'm not 100% sure if a 5.0 is setup like this, but most cars will run the pump when you twist the key to "crank" and then they look for signal from the distributor before they go ahead and tell the pump to keep running.
If that is how it works, it could be the wiring, the TFI module, distributor itself, or maybe the ECM. Or it could be something else.
Maybe a bad crash shutoff switch?
if you mean it only runs when cranking, but wont stay running after you let off the starter....
you might check the main pcm ground to make sure it didnt come loose. check it over by the coil where its shrouded in a plastic casing. it can come loose there and not look it, and it will give the same symptom you are describing.
