I can get it for $1000
It has 122K miles (I think) maybe 222K? and is currently registered and running.
What problems will I see using this as a donor to swap the Engine, Trans and FI setup into My '65?
I know the front bracket setup wont fit, but wasn't there something about the '87 5.0 block, pistons or heads that makes them different (undesireable for swaps)?
Aside from the speed density EFI, poor heads, flat top cast pistons and lowly cam, this can be a good foundation for a build, but you will use just the block and AOD. It is roller compatible, and can have parts swapped to make it a better engine. The heads and pistons are the real performance limiters, though. I'd not pay more than $100-200 for the engine (from a performance perspective you are buying just a block) and not more than $400 for the tranny... that's about half of the asking price and may not be worth it. You may be able to find them cheaper than that.
It is soooooooo worth it. Based on your 1000 dollar potential donor car option it'd be comparable in price. Especially since like Born said you're not going to end up with as much goodies out of that towncar as you would like. You could so easily get a MAF engine/t5 already pulled if you looked around for 1000 or less easy. It's your project though, have fun.
