87 notch LX, procharged and intercooled, perfect body fresh paint FS FT
yoshgixxer
York,PA
87 notch LX, procharged and intercooled, perfect body fresh paint FS FT in PA
I ADDED A BUNCH OF PICS..SEE BOTTOM OF AD for photobucket link
(car is my avatar pic)87 notch back car,original 4cyl chasis,car was striped down body worked and painted,car is very straight and only has a few very small chips on the hood,car was also R titled from a small hit in the left rear 1/4. NO FRAME DAMAGE it was all in the 1/4,i can take super close ups of the inside and outsde of 1/4 where it was hit was in the 1/4 panel. Only reason im selling it is its my dailey driver and i just scored a job far away so i dont feal like racking a ton of miles on this car.plus i need somthing better on gas. avg 11 MPG.Very dependable i never had it break down or leave me sitting,carb is dialed and dosnt run rich,bog jump or stutter.Fires right up everytime.
car is located in York,PA..i will travel or ship for sale
whole car was swaped out from a 90 GT,subframe,suspension,brakes,lines ,rear etc.
a short list of all thats on it
also car has about 2k on it since it was finished
ENGINE AND RELATED
Fresh 306,block was cleaned up,bored and checked out
new pistons,rings bearings and gaskets,New oil pump and timing chain/gear set.
FMS 303b cam,
GT40 heads with fresh valves,guides seats and matching spring set with port work
roller rockers
Moroso aluminum valve covers
Carb shop holly 750 blow through carb built for this car
Velocity racing carbhat
K&N filter
MSD bllet dist.
MSD 6al ign.
MSD blaster coil
MSD wires
new polished water pump
Flex fan
FMS Radiator(unistalled)
PROCHARGER P600B charger set at 11psi (have 14lb pully)capable of 20psi
The head unit was sent to ATI and had new bearings,impellar and seals put in it(have reciept)
Front mount intercooler
turboXS BOV
Aeromotive boost sensitive reg.
AN fuel line
Edelbrock electric fuel pump and filter
Optima spiral cell bat.
BBk headers and mid pipe
Flowmaster catback with chrome tips
all new hoses and vac lines.
SUSPENSION and REAR
Subframe connectors
Lakewood drag shocks and struts
1" lowering drag springs
8.8 rear with 3:73 rear gears with a all new seals and bearings,brakes and rebuilt posi unit
Weld drag lites with great BFG tires 15x9 rear 15x5 fronts
INTERIOR /EXTERIOR
Autometer,boost,oil gauges and shift light
Cervinis hood
Leather seats out of a 97 GT
New headlights with clear corners and markers
New aluminum heater core installed properly,
aluminum pedal covers
TRANNY
Tremic T-5 nice and tight,shifts perfect
Hurst short through and adjustable base
Hurst cover plate
FMS fly wheel
King cobra clutch
New UPR adjustable clutch cable
Aluminum UPR clutch quad.
id like to get $6500,will meet half way and can also ship the car at buyers
expense..i got a few pics ill take a bunch more when the weather clears up
will trade for a newer style mustang,fuel injected,Ram air TA, nice suv or other cars..let me know..must be in good dependable shape
give me your email i can mail you a boat load of pics
SEE PICS HERE! Image hosting, free photo sharing & video sharing at Photobucket
