88 Mustang 5.0 wont turn over 3500 rpms
lpp5.0
I have a 1988 Mustang GT 5.0 5-speed with speed density. At the moment it wont turn over 3500 rpms. I've changed the fuel pump, fuel pressure regulator, distributor, ECM, MAP Sensor and spark plugs. I'm getting fire to all 8 wires, the module tested good at a Auto Zone store and all I can think of next is the fuel injectors. Please help!!!!!!
clogged fuel filter? :shrug:
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
If codes aren't revealing, you might find the coil is going south. Ditto for the TFI (bench tests on intermittantly-functioning parts are hit or miss).
You are running copper spark plugs, right?
+1
Sounds exactly what I went through last year, I couldnt go over 3000 rpm, it turned out to be the TFI; I dumped the codes and everything...nothing. I eventually went to AZ and I tested the TFI myself about 30 times and it passed. I still suspected it for some reason, so I pulled a TFI form the junkyard and the car finally right; then I bought a brand new one right after that
exhaust
how about exhaust,,,clogged cats/muffler can cause lack of power
