I just checked the codes on my 88 w/ a 351 swap and I'm getting the following codes:
81 - Secondary Air Diverter Circut Failure
82 - Secondary Air Bypass Circut Failure
95 - bad fuel pump to ECU ground
what do these mean?
I understand I'll have to look into the ground for the fuel pump but what are the other two.
I just finished replacing about 80% of the vaccum line in the engine compartment and put a oil seperator in the car and decided to check the codes before I go get it emisions tested.
And it looks like to me the 81 and 82 failures are due to the Emissions parts.
My heads are not drilled for smog, but all the hardware is still hooked up.
what do these mean?
