89 Convertible Frame Broken?
  • Thread starter Thread starter mustangkarl
  • Start date Start date Apr 7, 2011
mustangkarl
31
Ashland Wi
Apr 7, 2011
  • Apr 7, 2011
I bought another mustang yesterday. a 1989 gt convertible. The motor for the top does not work so I have to raise and lower the top manually. On the ride home from where I bought it I put the top down and then back up with no problem. but today I lowered it and had to push it down a bit to put the cover on properly. When I went to put the top back up it no longer reaches the window to latch the j-hooks. Is it possible I bent the frame pushing it into place or maybe the hydraulic rams can't extend all the way without the motor?
90limited
276
Port Charlotte FL
Apr 8, 2011
  • Apr 8, 2011
The top shrunk while you had it down... I know that this does not sound possible, but it happens.
If I left the original top on my 90 down for a day or two, I would have to put weights on the front of the top to stretch it before it would hook. Even kept a ratchet strap in the trunk, in case of ran with no time to stretch, I could hook to a pole and "help" things along. You might consider adjusting the frame, but be careful if you have never dealt with convertibles before. Backing the J hooks out a couple of turns should not mess things up to much and might just give you the extra ¼” to get things hooked. If it is really tight once you get the hook in, be careful not to force the top latches. After a couple years of forcing the top closed with the latches, the pivot point in the latch wore out and I had to replace the driver’s side…
After replacing the top, I do not have this issue anymore. They way to avoid it is never leave the top down for an extended period.
90limited
276
Port Charlotte FL
Apr 8, 2011
  • Apr 8, 2011
Also, make sure to pull the top material out of the frame before fully retracting the top. The frame will pinch the top, causing damage over time and make it hard to fully retract.
D
Ds88vert
9
  • Apr 8, 2011
PM me with a good email addy...I have the full ford shop manual on the fox body convertibles. What you are talking about is the for and aft direction of the vert top...
mustangkarl
31
Ashland Wi
Apr 8, 2011
  • Apr 8, 2011
I just went outside and it latched as easy as can be. I find it amazing that a difference of 20 degrees can make a difference of 3 inches to latching.
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Nov 17, 2026
AeroCoupe
O
Resolved 89 Convertible help
  • obeone66
  • Aug 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2025
LILCBRA
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
