'89 GT surges then dies?
DemonGT
871
51
49
Sparta,WI
just bought a 89 GT and it has a built 306...TW heads TW stage one cam TW intake with the rest of the goodies and its even girdled....but some times when you start it it surges real bad then dies....was thinken mabe its running to rich? it has a adjustable regulator but no gauge....any ideas?
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
didnt think codes mattered as there is no check engine light
keep in mind the car dosnt die every time..after restarting/reving it awhile it will eventually find its idle and run good...
There can be codes set even without the Check Engine Light being on.
See the sticky "Help me create the Surging Idle Checklist" at the top of the forum for more help with your idle problems.
