Drivetrain 89 GT, Whining/whirring from trans with clutch engaged
  • Thread starter Thread starter FetusLasVegas
  • Start date Start date Oct 7, 2018
First Prev 2 of 2
FetusLasVegas
78
Chicago
Oct 16, 2018
#21
  • Oct 16, 2018
  • #21
Well, I had a really busy weekend, which included a no-start (fixed), and would have loved to get back into this today, but two things, my wiring harness that I waited two weeks for that should be the solution to my start/idle/cruise surging came on friday and is ready for install, and, last time I drove the car, out of nowhere, as if to say, 'hey, guess what? you ARE going to have to pull the tranny.' Out of nowhere, I now have a small grind going from 3-4th. Shifts fine at idle.
I have only used mercon v and dex/merc atf since I have been working on it. I have no idea what was used before I owned the car. I'm guessing the 4th gear synchro is delammed and on it's way out. Looks like at least I'm going to be in for a baby rebuild.
1. Having never worked on a trans before, with the videos and literature out there, would I be able to determine what needs replacing on my own?
2. Special tools? From what I've read: dial indicator, snap ring pliers, hydraulic press? I've only seen the hydraulic press in one of the many posts I've read?
3. Can I continue to drive skipping 4th? I have not driven since I noticed the grinding, prob only gone into 4th five or so times since noticing?
4. Best or recommended small rebuild kit. Obviously looking to keep it as cheap as possible, without needing to do this again in the near future.
Sparky714
5 Year Member
Oct 16, 2015
375
210
73
North Dakota
Oct 17, 2018
#22
  • Oct 17, 2018
  • #22
LMR has a rebuild kit with everything you need, https://lmr.com/item/M7000A/85-95-Mustang-T-5-Transmission-Rebuild-Kit, or search ebay, might find it a little cheaper. And yes, you can rebuild it yourself, not that difficult.
FetusLasVegas
78
Chicago
Oct 17, 2018
#23
  • Oct 17, 2018
  • #23
Thanks for the input and encouragement. Still looking to have the answers to #2 and #3.
Boostedpimp
20+ Year Stangneter
May 8, 2003
1,451
493
154
NJ
Oct 17, 2018
#24
  • Oct 17, 2018
  • #24
Skipping a gear isn't going to be an issue, it'll just get annoying is all.
If it were me, I would pickup a used cheap T5 which would more then likely need a rebuild anyways and rip that a part and learn while just driving the car with its currently T5 skipping fourth and checking fluid levels
FetusLasVegas
78
Chicago
Oct 17, 2018
#25
  • Oct 17, 2018
  • #25
I wish I had the budget to do that
JD1964
there is enough sticking out to grab on to
3,468
1,552
194
Maryland
Oct 17, 2018
#26
  • Oct 17, 2018
  • #26
I skip gears routinely. Most often 2nd to 4th, skipping 3rd. I like to hit second good sometimes. In town, the top of second is fast enough. Then let off and cruise in 4th
Reactions: FetusLasVegas
FetusLasVegas
78
Chicago
Nov 6, 2018
#27
  • Nov 6, 2018
  • #27
I found a decently cheap T5 near me out of a 95. I believe I read somewhere that the bell housing is different, but other than that, is it a direct swap? Ideally I'd like to swap the 95 in and rebuild my current trans at me leisure.
First Prev 2 of 2
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
