Ok guys, it's been a while so you may need to go back to page 1 of this post and look at my progress but I started looking at my car again this weekend.
I rented a compression tester from autozone and tested all my cylinders. They all went up to 110 PSI and stayed there for 2 minutes no drop in pressure. This makes me thing there is no head gasket problem now...
I am at a loss. Why am I still losing antifreeze via the overflow? Is there a way to test my radiator for functional problems? Is there something else I should test?
ha ha ha I took your direction and referred to page one: 'I started noticing when I would "get on her" a little here and there the engine was heating up more than normal.' Dude I stated that I had the same issue with my 'Stang because of the single-core radiator. All warmed up crusin' the freeway, drop down to 3rd stand onnit hit 115 then shift to fifth and hold it @ 120 then I hit an off ramp and while idling at the light it begins to puke coolant. ie - it's blowin' up in the overflow reservoir and squirtin in the street.
What am I missing?
