90mm mass air + INJECTORS???
ritter5.0
48
fort drum, ny
:lol:I WANT TO RUN A 90MM MASS AIR. HOW DO I GO ABOUT INSTALLING? IM SURE I WILL NEED A TUNE.
ALSO I WANT TO RUN BIGGER INJECTORS BUT DONT KNOW WHAT SIZE. I WAS THINKING 60LB BECAUSE I PLAN ON PUTTING ON A KENNE BELL. WHAT DO YOU THINK? CAN I RUN 60LB WITHOUT SUPER CHARGER?
SOME OF MY MODS ARE* E-CAM,COLD AIR, PULLIES, ROLLER ROCKERS, STOCK BLOCK, 75MM THRODLE BODY, TRICK FLOW UPPER AND LOWER, LONG TUBES, XPIPE NO CATS, FLOWS, MSD IGNITION, 410 GEARS, STOCK HEADS, 255 FUEL PUMP, FUEL PRESURE REG
You wont need a 60# inj with that set-up, even the 42# is a little too large. To run the Lighting meter you will need a chip, under 500Hp they work well but are easily maxed out...Id prefer a PMAS or Pro-M meter.
You'll need some piping and silicone connectors as well since the 90MM meter is 3.54" in diameter...
Running that large of an injector NA will be an issue, wait till you install the blower since youll need to swap lower intakes for the KB, it only works on GT40 lower.
