im putting in a used top/frame onto my 91 fox (actually already put in top/frame...now doin the little stuff). when putting in the hydraulic lines, it got kind of confusing. first, does it matter which t-fitting goes into the pump? there are 2, i dont know if its supposed to be on one side or the other. bad?
second, the hydraulic lines that run from the rams (upper/lower), the route? i dont want them to get pinched. (pics if you have em
third, teflon recommended after removing the fitting from the pump and rams, and putting them back in?fourth, since i removed the fittings, hydraulic fluid leaked out, so i will be adding. ATF fluid i heard is ok? is there a method to bleeding the system, or do you even have to
last, does anyody know what kind of glue/adhesive i would use to re-attach the vinyl to the rear window glass? it is seperating a little.
