92’ Bucking Issue
bear108
222
Pa
About 20 years ago, I rebuilt the entire top end including cam with all new aftermarket parts. I have a 92 lx 5.0. When it was complete n back on the road, I have this bucking issue in lower gears. I have lived with it and just worked the clutch n gas to settle it down. I was told way back when that it’s was kind of common issue for what I did. The solution was to get a custom burnt chip and that would fix it. Now years later, I am curious if there is some type of plug n play, that would eliminate this problem?? Any help or advice would be greatly appreciated!
I have to ask have you checked for codes? I fought the same issue with my 89gt but couldn't pull codes, computer would not communicate with the scanner and some other self inflicted problems. There was also an issue with the tps having a dead spot, my point here is a tune likely will do nothing for the bucking issue, what cam do you have? Other mods done? You may have more than one problem.
Dump codes sticky
Look at the top of the 5.0 Tech forum where the sticky threads are posted. One of them is how to dump the computer codes. Codes may be present even if the CEL (Check Engine Light) isn’t on. You don’t need a code reader or scanner – all you need is a paper clip, or if your lady friend has a hair pin, that will do the job.
I highly suggest that you read it and follow the instructions to dump the codes. http://www.stangnet.com/mustang-forums/threads/how-to-pull-codes-from-eec4.889006/
