92 5.0 almost starts
  • Thread starter Thread starter Steverino
  • Start date Start date Sep 23, 2026
Steverino
Ventura County
Sep 23, 2026
  • Sep 23, 2026
I Recent did some work where i had to take the upper manifold off (GT40 manifold). I replaced the fuel filter and battery cables. (I have an MSD).
This is all stuff I have done before. Everything seems to be okay.
1) I do not hear the fuel pump come on when I turn the key to the run position... (It always has until now).
2) I have ford cod reader.. (last used 10 years ago). When I turn the key to the run position and press the test button... nothing happens. No test cycle and no codes. Should something happen even when cold?
I would think the fuel pump is bad, but could the MCU have gone out,
When I turn the key to start, it cranks and kind of starts, but dies like its not getting gas... No fuel pump noise. I did buy a new fuel pump relay, it did not change anything, That is another odd story.
Fuel pump or worse issue with the MCU?
AeroCoupe
6,250
4,336
183
Claremore, OK
Sep 23, 2026
  • Sep 23, 2026
Typically if you cannot read codes the ECU needs to be refurbished. Is the battery in the code reader good? Could also be that the code reader died.
Reactions: DadLife0724
Steverino
Ventura County
Sep 23, 2026
  • Sep 23, 2026
I did put new batteries in the tester. I am hoping the tester died... I don't know anyone with ODB 1 I can check against......,
I see Autel sells a cable that will connect ODB I to OBD II tester,. Has anyone tried that?
General karthief
Mod Dude
Aug 25, 2016
28,138
10,759
213
polk county florida
Sep 23, 2026
  • Sep 23, 2026
Does the CEL come on when you turn the key to on?
You can do the jumper wire test to make fuel pump run on the test connector.
Electrical Thread 'How To Pull Codes From EEC-IV In 86- 95 5.0 Mustangs'
Jan 27, 2016
@Noobz347 - The code dump procedure isn't in the sticky - you may want to add it...
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for...
  • jrichker
  • Forum: Fox 5.0 Mustang Tech
And here...
Thread 'Cranks OK, but No Start Checklist for Fuel Injected Mustangs'
May 22, 2006
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 26-Jul-2017 to add fuse link diagram.
All text applies to...
  • jrichker
Any questions or more importantly, find a resolution post it here.
It would be a good idea to consider sending that 30+ year old computer.
I recommend the ECUXchange, they have checked out several for me and others here, worth the money.
Reactions: Mcmahst and AeroCoupe
AeroCoupe
6,250
4,336
183
Claremore, OK
Sep 23, 2026
  • Sep 23, 2026
Ford Mustang 5.0 A9L A9P C3W A3M X3Z ECU Repair Service
Ford Mustang 5.0 A9L A9P C3W A3M X3Z ECUEngine Computer Repair ServicePlease fill out the R&R form here once you've placed your order.A Trusted Product with LIFETIME WARRANTY QUICK TURN AROUND TIMEDomestic and International Shipping available! Our Team is Available Monday - Friday 9am to 5pm...
www.theecuexchange.com
General karthief
Mod Dude
Aug 25, 2016
28,138
10,759
213
polk county florida
Sep 25, 2026
  • Sep 25, 2026
Thanks for linking that, got a thumb cramp, you know, old man stuff.
Reactions: AeroCoupe
D
1989 mustang 5.0 crank no start
  • Darkstang302
  • Nov 10, 2026
Fox 5.0 Mustang Tech Sunday at 11:13 AM
nickyb
I
Innova scanner not working 88 5.0
  • Idkwhatimdoing
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2026
Steverino
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
