92 Fox-no Lighting Issue
G00nies
149
1992 fod 5.0l GT
So, instrument cluster lights stopped working except for Hi Beam and other warning lights (which I tested and still work), but no backlighting exists. all fuses are fine. Turn signal indicators are also operational.
Dimmer switch works, but only controls the dome light on/off at this time.
Tested the headlight switch and it ALSO works.
is there a component that I am overlooking? Illumination relay?
Its been a few months since Ive driven the car regularly, but they were operational (last I remember) a few months ago.
Help!
Ah. Sorry I don't have the specific wiring diagrams for that.
Sounds like you lost the power that feeds the cluster for illumination. have tou pulled the cluster to see if any part of the ribbon circuit tape on the backside has burned out? If I had wiring diagrams I could tell you which wire was the feed from the dimmer to the cluster
It's the pink wire coming from the dimmer iirc
I can MANUALLY power up either side of the cluster with my power probe...
Before investing in a new one, take yours apart and clean it. The copper contacts can get corroded.
JUST REMOVED AND CAREFULLY CLEANED THE RHEOSTAT AND CONTACTS. it certainly helped the quirky dome light on/off point, but still no iinstrument cluster backlighting.
Also removed the 5 or 6 194 bulbs marked "ILL" for backlighting and also swapped contacts with known working ones, still no backlights.
BRAKE HI BEAM BATT Check Eng Low Coolant AIRBAG all work just fine. and turn signals
Trace the contacts for the bulbs back to where they plug in. Using a DMM, test for voltage on the harness when you put the lights on.
If none there, then you shou;d test the dimmer next for voltage out to instrument ILL. I have these diagrams home
Thanks, that would be helpful, I've had trouble finding the proper wiring diagrams going FROM the dimmer TO the cluster. I did check for power and ground at the H/L switch and it checked out
Sounds more and more like the dimmer is your problem.
Highly recommend picking up a 1993 Mustang EVTM off ebay. Every wiring diagram you'll ever need with colors and such for your car.
I'll take a look at my diagrams tonight, but it's for a 1988. May be different
Problem SOLVED! I deserve a whole bunch of ribbing but didnt have a proper schematic for my car and missed the SECOND 5A fuse on the panel once I got a LEGIBLE wiring diagram from PRO DEMAND.
Went right to it and VIOLA!
I went full retard on this one, but thanks for the help. On the Bright side, I learned alot about electrical !
I replaced a dimmer and multi function switch because of that fuse. That's why I asked about fuses in my first post.
Assume you mean the one is slot 13?
Sent from my iPhone using Tapatalk
