- Dec 28, 2011
- 101
- 0
- 17
Was wondering if anyone has any ideas because I don't know much of anything besides the very basics of the 302, or any engine for that matter. I always don't quite know how to describe the problem but I'm going to try my best.
6 months ago I bought a 92 GT with unknown miles down in Florida (I live in Missouri) for 2 grand. According to the guy it sat in his backyard under a tree for 8 months before I bought it, because he never got around to building it. He drove it 5 hours towards me in Florida, where I met him and then proceeded to drive it 15 hours back to Missouri. Car ran like a dream. Turns out the gas tank had rusted out and by the time I got it back all the rust had pretty much blown through the entire fuel system and I had to replace everything from the fuel tank to the injectors. Since then I have put on a gt40 upper/lower, bbk fender-well cai, new tps, new iac, 24 lb injectors with matching maf housing, all new required gaskets, ac delete/smog delete, 3:73 gears in the rear. I have been through the surging idle checklist and have the timing, tps, etc. all set correctly. Guy I bought from said he "thinks" it "may" have a mild cam in it. I don't know because I havent been any deeper than the intake.
Now the problem is that the car still feels just... slow. Sure, I can smoke the tires allllll day in first but other than that it really doesnt impress. However, the problem is sometimes going into second and a lot of times going into 3rd. If I am getting on it, say I shift into 2nd at 35 hundo / 4 grand rpms, I will come off the clutch and give it gas and as the rpms start to go up in second gear the engine sound will change, it will get higher like its struggling and then drop a couple hundred rpms and then scale up again as normal, does it worse in 3rd gear. I really wish I had a better way to describe whats going on but I don't. An equivalent scenario might be that as you are blowing up a balloon and as you are blowing it up some air escapes and it deflates a bit before you blow it up the rest of the way... lol
Anyway, Im just trying to trouble shoot the problem. Could it be a bad water pump, bad compression, bad head gaskets, bad axles? I really dont know and I dont know enough to not throw parts at it. Sorry for the
ty vague description of whats going on. Hopefully someone understands wtf I'm trying to get across, haha.
Thanks guys!
ty vague description of whats going on. Hopefully someone understands wtf I'm trying to get across, haha. Thanks guys!
