92 stang problems
  • Thread starter Thread starter boxcarracer89
  • Start date Start date Sep 10, 2010
boxcarracer89
153
I live in Roswell NM
Sep 10, 2010
  • Sep 10, 2010
I have a 92 gt and it sputers if u get on it and if u turn on the lights it will die on u, it is a 306 stock cam, edelbrock heads gt 40 intake, stock bottom end. I pulled it out of another stang that I couldnt get a title for and it ran great then no problems or hesitations or n e thing! So i am assuming it is an electrical problem??
skunk21
1,203
Taxachusetts
Sep 10, 2010
  • Sep 10, 2010
for starters check your battery at rest ( let it sit for long time or over night) and check it. a normaly charged battery should be about 12.6-12.7 volts. If it's less like say 12.4 or lower then the battery is low on charge. Then test the charging system should get 13.5-14.4 volts to be normal charging range for the alt. Problems could be a worn battery, dead cell, wiring problem from the battery to alt, bad alt or drain. If all systems check out the we will move on but from the sounds of it ( spitting under load and dying when the lights are on ) it could be battery/charging related.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 10, 2010
  • Sep 10, 2010
If the car is drivable, go to the nearest large auto parts store. They will check your charging system for free.
If it isn't drivable, pull the alternator off the car and take it to the same auto parts store. They will check your alternator for free.
When you remove the alternator for testing, put a battery charger on the battery. The alternator will not charge if the battery voltage is too low. You should see 14 volts at a fast idle with nothing on except the engine.
boxcarracer89
153
Sep 12, 2010
  • Sep 12, 2010
I got a brand new battery and the charging system was good!! It runs fine at idle but when i start driving it sputters pretty fast and dies out, not enough fuel??
HISSIN50
34
129
Sep 12, 2010
  • Sep 12, 2010
Time to pull codes.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 12, 2010
  • Sep 12, 2010
What does the voltmeter show at 1200 RPM with the A/C on high? It should be at the middle mark on the stock voltmeter. If not, you still have electrical system problems.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
