92Grand to 91 mustang AOD swap
The shift arm is the only thing I can think of that would be different install wise. There are several things internally that are different but You probably won't notice any difference driving the car. To set the Tv pressure you install a trans pressure gauge into the tv port and set the pressure at idle to between 2 and 5 psi by changing the adjustment on the throttle body end of the tv cable.
now that's tech!:nice:
