93 5.0 rich on highway top of 3rd/4th gear
Mintsick
589
39
68
West Lafayette, IN
Something I just noticed recently, I was merging onto the highway last week in 2nd gear (2.73's) and at WOT no smoke in 2nd, shift to 3rd no smoke at first but right around 3500-4000 rpm I could feel the car stumble a bit and noticed black smoke coming out of the tailpipes. Yesterday I got on it in 4th gear on the highway to pass and it did a similar thing in the same rpm range as it did in 3rd gear. Lower gears do not produce this behavior even at WOT. The engine runs excellent (82k miles), stock everything under the hood besides a 70MM MAF from a 94-95 5.0 stang, 87 octane, stock timing (or should I say I've never touched the timing since I purchased it in March of this year).
What are some things I should check here...plugs, fuel pressure, noticeable fuel leaks at the injectors/rail, timing?
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
