93 cobra bumper question
  • Thread starter Thread starter TrophyHead
  • Start date Start date Jul 5, 2007
TrophyHead
1,195
11
49
PA
Jul 5, 2007
  • Jul 5, 2007
Before I order this I want to make sure.
The strap of metal that bolts through the rear tail light panel to hold my GT bumper is in bad shape. Will I have to reuse this if I go with a Cobra bumper? I called Cervini's with not alot of help. Thanks
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Jul 5, 2007
  • Jul 5, 2007
That little strip holds it in place, so I'd say you'd need to put one on there. You could probably put it on and get lucky but I wouldn't personally try or suggest it.
TrophyHead
1,195
11
49
PA
Jul 5, 2007
  • Jul 5, 2007
That's going to be a fun part to try and locate. Anybody ever see one on a website or anything?
Ozz
3,514
66
109
Canton, MI
Jul 5, 2007
  • Jul 5, 2007
No but I never looked either. Try Mustangs Unlimited and see if they have it.
I'd be looking for someone parting out a GT and ask if they can grab that for me. For 10-20 bucks or so it should be worth their 30 minutes or less to take the bumper off, I'd imagine.
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Jul 5, 2007
  • Jul 5, 2007
I'm sure its no big deal to find one in a junk yard for a few bucks.
Ozz
3,514
66
109
Canton, MI
Jul 5, 2007
  • Jul 5, 2007
that too if you have a pick n' pull.
I know the ones here where you can't pull your own parts wouldn't bother with such a piece
bditty50
170
Tampa, Florida
Mar 22, 2008
  • Mar 22, 2008
I was thinking about installing a rear cobra bumper on my 89 coupe since I need a new rear bumper. I just want a bumper that fills in those stupid panels on the bottom of the quarters. I'm thinking about buying one and then trimming it to look like a lx bumper just to have the full wrap around one piece bumper look. What do you guys think? You think it will work?
SuperStang83
1,693
Boyertown, Pa
Mar 22, 2008
  • Mar 22, 2008
Yeah you need that piece. Just hop in a junk yard and get one or look on Craigslist for someone parting a car out.
bditty50
170
Tampa, Florida
Mar 22, 2008
  • Mar 22, 2008
what piece?
SuperStang83
1,693
Boyertown, Pa
Mar 22, 2008
#10
  • Mar 22, 2008
  • #10
The metal piece.
D
Demented4.6
1,055
DAYTON, OHIO
Mar 22, 2008
#11
  • Mar 22, 2008
  • #11
try these guys www.greensalescompany.com
They had them along with the brackets that held on my GT sideskirts when i couldn't get thema anywhere. They stock old OEM parts that the dealers quit stocking
STMPEDE
Southeastern Pennsylvania
Mar 22, 2008
#12
  • Mar 22, 2008
  • #12
I have the Cervini's rear bumper cover, and I definitely had to re-use the metal mounting bracket. I also had to do some modification to it to get it to work. Instead of the posts of the bracket coming through the holes in the inside top lip of the Cervini's bumper (like the GT was installed), I had to cut off the lip on the Cervini's piece altogether. I then drilled holes in the top of the bumper (under where the tailights would sit) and down through the top of the bracket. I then used small stainless bolts/nuts to hold them together.
The bumper would not line up without doing this, but I also noticed that ultimate fittiment seemed easier doing it this way. In the end, the thing looks great and nobody knows the difference.
The metal bracket still mounts up to the car using the posts/nuts, they just don't go through the lip in the bumper first.
By the way, CJ Pony parts has a junkyard full of Foxes on-site, and they will often pull off whatever you're looking for and send it to you at a cost (luckily I only live about 40 minutes away).
Which tailpipes to go with for a cobra rear bumper
  • AnthonyA1234
  • Jul 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2025
rednotch
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
SN95 The Unicorn
  • HANO Motorsports
  • May 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
HANO Motorsports
